Dakzuki
Aug 05, 2013Explorer II
smokey_truck wrote:
I am campin in VA beach area and when I turn on my Diesel Generator after 14 min it cuts out and I see this error in the panel Oil Temp-press!. This is 2013 Winnebago View with 12 Hours on genney. Checked the oil level it is between Min and Max lines
Does anyone have any idea with this, is it just adding more oil.
Thanks for any info
Ganesh
You have a two year warranty on that generator. Unless you can easily fix it with more oil (up to FULL mark and not beyond...DO NOT overfill a diesel) and you don't know much about troubleshooting the issue go get it looked at by an approved warranty center. It could be just a failed sensor. My RV dealer said after the first year, take it to Cummins for warranty work when mine died. They took it in and replaced the failed fuel pump (which I had already diagnosed) under warranty.
38,766 PostsLatest Activity: Jan 10, 2026
