lj2654's avatar
lj2654
Diesel Pusher Air Filter change
I was wondering how to really know when to change an air filter on a CAT engine.
I have the vacuum gauge that is supposed to give you the info but how reliable are they?
The filter for my engine is a large canister that has to be changed out but its more awkward to do than hard.
I can remove the lower hose and visibly see it but that doesn't tell me anything!
  • Air filters are replaced for TWO reasons:
    1. Restriction, as indicated by air filter minder reading.
    2. Age. Made of paper and resin, they deteriorate. Three years is a reasonable "safe life".
    And, the air filter minder needs to be tested annually. Pull off the rubber hose that goes from intake to filter minder and suck on it. The filter minder should peg at max restriction and hold that reading until you push the release button. Truly a 1 minute operation.
