bdpreece
Aug 06, 2019Explorer II
You are correct in thinking the side radiator is more desirable however the rear radiator coaches should not be something you need to avoid as a whole. What I would recommend to avoid is a rear radiator coach where the radiator and charge air cooler are sandwiched together. I had a coach like that and all kind of debris gets between the radiator and CAC and it is almost impossible to get them clean without removing them from the coach. As long as the radiator and CAC are mounted separate from each other you will have no problem.
