FIRE UP wrote:
JohnQ wrote:
We have a 2002 Jetta TDI manual transmission. The VW Automatic transmission are NOT 4 down towable. First the Jetta as a TOAD is great, can't even feel it's back there. Second, it is a good 4 hour PLUS job to install the tow brackets and wire it up. The shop where we had it done was mumbling a lot about NO MONEY MADE ON THAT JOB. Third is the Jetta itself, if you are of any "Size" be aware that it is NOT a comfortable vehicle to drive on long trips. That left foot area is extremely uncomfortable as well as the center console hitting your right shin. Lastly, the redeeming grace so to say about the TDI's are the FUEL (not Gas) Mileage. I have never seen ours drop below 44 mpg, and on the open road with THE CRUISE CONTROL ON at 70 mph on I-5, it does exceed 58 MPG.
With all of that said, if I were you, I would look for a TDI PASSAT manual transmission station wagon. You won't get as good fuel mileage but the comfort driving it will be worth it.
JohnQ,
May I ask, did you find any info at all concerning the towing or non-towing of the "stick" Jetta? As I stated in one of my earlier answers here, I'd have loved to have purchased a newer Jetta or Bug TDI for our toad but, we were under impressions that there was no authorization from VW stating that they were flat towable. Now I know you said yours was a 2002 and I'm talking 2011-12 so, it's apples and oranges, so to speak. I dig these cars and TDIs in general. I love the power. I sure wish VW would authorize the 2013 Jetta TDI Auto to be flat towed, I'd have one in a heart beat.
I'd do all the setup myself on the base plate install and wiring so that's no big deal.
Scott
It is my understanding that the generation of VW platforms, the MK IV (Jetta's & Beetles) used a common manual tranny that flat towable. I checked it out via the Tow Guides here. That MK IV series ran from 99.5 through 2004, then it was upgraded. Those upgraded platforms I do not know anything about. None of the VW Automatics were ever towable. That base plate setup was a bear to install. Basically the te ch had to disassembled the entire front end, install the base plates then re-assemble the front end again.
