Golden_HVAC
Dec 10, 2015Explorer
They are both class A chassis. Same engine, but the Flair 27' long model only has a 16,000 GVWR, and only a 158" long wheelbase that happens to be found on the short class C chassis.
If you go to the class C, then you get a 2 valve V10 engine, with less horsepower in the vans (smaller radiator too) and the 3 valve V10 in the motorhomes and pickups is 362 HP hooked up to the larger capacity transmission tool.
Good luck,
Fred.
Good luck,
Fred.
