MrWizard
Dec 28, 2017Moderator
You can bet on the pink slip
If the title says 10 cylinders, then you have a v10
They are not common that early, but they were/are available
It was an option that most builders did not order, because the 460" cost less
The Triton v10, is also smaller, 413CuIn if my memory serves me
10% smaller, higher revving, more power, better fuel economy, weighs less
Check the chassis designator
Some mfg, might have bought the 'E' chassis then built class A coach, not illegal just different way to skin the cat
