- DakzukiExplorer II
Gonzo42 wrote:
The MSRP on the View is about $4K more than the Navion.
http://www.rvguide.com/specs/winnebago/class-c/2008/view/24h.html
http://www.nadaguides.com/RVs/2008/Itasca/M-24H-DODGE-SPRINTER-DIESEL/3048295/Floorplan
The Winnebago and Itasca web sites show the exact same MSRPs for the View and Navion. - Gonzo42ExplorerThe MSRP on the View is about $4K more than the Navion.
http://www.nadaguides.com/RVs/2008/Itasca/M-24H-DODGE-SPRINTER-DIESEL/3048295/Floorplan - 9erExplorer
rr2254545 wrote:
Made on the same production line, only difference with be decor and cosmetics
as an owner of a view and looker for yrs,this is spot on - DakzukiExplorer IIDo your own research. Go to a dealer that sells both (like I did), get order sheets for both, and compare specs, price.
- BobboExplorer IIIThe things I marked in red are also in my Winnebago Class C. They may have been options, but they were included when I walked onto the lot.
pnichols wrote:
From reading these forums down through the years regarding what folks do and don't have in/on their Class C rigs, I'm not sure that Itasca isn't a bit "higher end" than the standard Winnebago units .... or least maybe the Winnebago's Itasca line used to be.
For instance, my stock 2005 Itasca Class C came with such things (some of which might have been optional within Winnebago's namesake line) as:
- Heated tanks
- Outside shower
- Dual 12 volt batteries
- A built-in charging station including 4 FRS walkie-talkies
- An automatic electric coach step
- An outside entertainment center with radio, TV outlets, 120V/12V outlets and TV shelf ,,, including a separate antenna on the roof for the ET center radio
- Key fob controlled cab locks
- Heated and remotely adjustable cab mirrors
- Heat shields underneath between the exhaust pipes and the cab floors
- A surround speaker system in the coach
- Cab RV radio with controls on the steering wheel
- Two of the seven exterior storage cabinets go laterally across under the coach floor for storage of long items
- All exterior storage cabinets are carpet lined
- Crome wheel covers
- Mounted full spare tire, including some changing equipment for it
- Aluminum driver/passenger running boards
- Gravity locks on all cabinetry drawers
- Solid oak miter-jointed cabinet doors
- Digital furnace and air conditioning controls
- Multi-ducted heating and cooling
- Built-in fresh water filtration system
- Shower with ON/OFF control on the shower head
- Included curtains for blocking off the cab area, the rear bed, and the cabover bed
- Dual floor covering ... galley area vinyl, other areas carpet
- Separate enclosed cabinets for the 120V AC fuses and 12V DC fuses - MutinyguyExplorerSame MH, just different fabric and color scheme availability...don't make this too difficult...
- fortytwoExplorerThey sell the identical units under different names to get around exclusive territorial rights a dealer has. Two dealers in an area supposed to have only one. Great for Winnebago; maybe not so for dealers.
- pnicholsExplorer IIFrom reading these forums down through the years regarding what folks do and don't have in/on their Class C rigs, I'm not sure that Itasca isn't a bit "higher end" than the standard Winnebago units .... or least maybe the Winnebago's Itasca line used to be.
- Heated tanks
- Outside shower
- Separate enclosed cabinets for the 120V AC fuses and 12V DC fuses - DakzukiExplorer II
Jim Shoe wrote:
Sounds like the biggest difference is spelling. :)
You get more letters with a Winnebago. I guess that's a difference. - Jim_ShoeExplorer IISounds like the biggest difference is spelling. :)
38,777 PostsLatest Activity: Jun 28, 2025
