OutofTime wrote:
I have updates. Today I worked with my brother and we got the base timing set to 4 degrees BTDC using a timing light. Once computer advance turned on it advance to around 16 BTDC at idle. It seems to be idling much better and will idle around 850rpm or so when warmed up and on closed loop running.
However, it's still running a bit rich and still stumbling and falling on its face when revved. I pulled the IAC, cleaned it and the bore it sits in and checked for operation. I did see the pentile tip move in the throttle body when I turned the key to the run position.
I checked the voltage on the TPS and at full stop it read .568V, which is within spec I believe.
At this point I'm thinking my next move to fix this rich running is to replace the FPR.
The advance at 16 after connecting the distributor wire is correct.
Idle at normal operating temp should be 800rpm. There is an idle set screw covered by the factory on the front side facing forward. Is it covered? If it is don't mess with it. If it isn't covered then it's likely some PO did mess with it.
The coolant temp sensor in the front side of the intake manifold will need to be checked. If it's running rich after warm up it is likely bad.
Get a ohm meter and ohm it out.
Coolant sensor approximate resistance specifications:
177 ohms @ 212 deg. F. or 100 deg. C.
241 ohms @ 194 deg. F. or 90 deg. C.
332 ohms @ 176 deg. F. or 80 deg. C.
467 ohms @ 158 deg. F. or 70 deg. C.
667 ohms @ 140 deg. F. or 60 deg. C.
973 ohms @ 122 deg. F. or 50 deg. C.
1188 ohms @ 113 deg. F. or45 deg. C.
1459 ohms @ 104 deg. F. or 40 deg. C.
1802 ohms @ 95 deg. F. or 35 deg. C.
2238 ohms @ 86 deg. F. or 30 deg. C.
2796 ohms @ 77 deg. F. or 25 deg. C.
3520 ohms @ 68 deg. F. or 20 deg. C.
4450 ohms @ 59 deg. F. or 15 deg. C.
5670 ohms @ 50 deg. F. or 10 deg. C.
7280 ohms @ 41 deg. F. or 5 deg. C.
9420 ohms @ 32 deg. F. or 0 deg. C.
12300 ohms @ 23 deg. F. or -5 deg. C.
16180 ohms @ 14 deg. F. or -10 deg. C.
21450 ohms @ 5 deg. F. or -15 deg. C.
28680 ohms @ -4 deg. F. or -20 deg. C.
52700 ohms @ -22 deg. F. or -30 deg. C.
100700 ohms @ -40 deg. F. or - 40 deg. C.
For TPS info:
https://www.gmcmi.com/wp-content/uploads/2013/02/TBI-Initial-calibration.pdf
