We tow a Jeep Wrangler 4 down behind our Winnebago Journey using a Roadmaster Stirling tow rig. We have experienced irregular front tire wear in the form of flat spots. Front end of Jeep has been alig...
Community Alumni
Mar 23, 2016
Approved
I have the same problem with my tires but not so much as to worry to much about it. I think my problem is the tires as they get older I have more uneven wear. I also have had some tire damage when 4 wheeling going over rocks and hitting bumps. When I get new tires all is good till they get worn down a little and beaten up. I am running BF Goodrich 31x10:50 ATs with can be a bugger to balance too at least from my experience, was thinking about Goodyears since they went to a tri-wall Wrangler but not sure. Just FYI I have towed the Jeep a 1999 about 100,000 miles with only one issue last fall and that was my fault. I think the biggest thing is to get the tow set up done right in the beginning tow bar level brackets attached to the frame. JimR
