Currently towing a 2010 Honda CRV (3,400 lbs.) with my 2011 Fleetwood Southwind V10 gasser. Towing capacity for the RV is 5000 lbs. Am considering a 2014 Ford "Edge" that is about 4,400 lbs. Should I ...
I would not be concerned. Yes, you may see a little change in your mileage. You may change your driving habits and get better mileage. Locate where your engine, differential and speed gives you the best mileage. Dropping speed a little could change mileage.
