agesilaus
May 08, 2013Explorer III
dinghy towing odometer
I'm not usually seen over here. But I was just wondering, does the odometer on your dinghy keep turning when you guys pull it? How does that affect your warranty if it does.
shoreco wrote:Fifty4F100 wrote:
My 05 PT Cruiser records towed miles. I have to have the ignition on to unlock the steering wheel.
There should be a fuse you can remove to prevent this from happening....
Goldencrazy wrote:CA Traveler wrote:
Ignition on for the CRV, no mileage recorded.
My 04 CRV has 55K towed miles and 55K driven miles.
Come on. You must have driven the toad a little.
wa8yxm wrote:
There are 3 ways the odometer works depending on the car.
I have never seen, but did read, of a car where the speedometer was driven off a cable attached to the left front tire (not powered)... Popular Mechanics. back in the late 1960's A story series they published called Gus Wilson's Model Garage.. now as I said I have never seen this.
Most cars and trucks it is driven off the transmission output shaft. Older cars it's a cable drive, which means it's all gears and cables, and if the shaft is turning it's counting the miles.
modern cars it's an electronic linkage and if the ignition is off, it's not working.
