supercub's avatar
supercub
Direct TV installation, plus a whole lot of other stuff
Here's what I have
TV flat screen
Receiver/surround sound box
Blue Ray
Direct TV receiver
Switch/selector box (for selecting cable, sat, ant etc)
Everything is up and running using the Sat dish, which is a Traveler HD Sat Dish. The surround sound works.
I have a coax from the sat dish going thru a SWM direct tv convertor, then out to the direct tv receiver. HDMI cable out from the Direct TV Receiver box down to the surround sound box. HDMI cable out from the blue ray to the surround sound box..........and an HDMI cable out from the reciever to the TV........this all works.
My problem is........I've by passed my selector box, I need to figure out how to get a sat signal from the Direct TV Receiver box to the selector box.
The selector box already has a coax from the rear bedroom TV. down from the roof antenna, and from the shore power cable. so it's all wired properly, just no sat signal to it.
Seems like I need to run a cable from the direct tv receiver box to the selector box.....trouble is, there's no coax out on the sat receiver..........confused??? I know I am. Thanks
Brian
  • Dave at Sats2Go in Houston TX set ours up. I'll try to explain what he said he did: In the front, he installed a "splitter" aka diplexer with a cable to the selector box. In the back by the TV he installed another "splitter" aka diplexer. To access cable or satellite I use the "input" button on the DirecTV remote. You need to make sure the diplexer types carry power. If you are ever in the Houston area, call Dave at Sats2Go. He's the RV satellite "guru" His work is fast, professional and fair priced.
  • Go out and grab an RF Modulator. This will allow you to use the receivers red/white/yellow output (Composite) and convert it to coax output. They cost less than $40 and you will be able to feed this to your selector box. This output will be in SD and not HD but that's your only option unless you want to add HD wiring (new HDMI cabling) or a wireless HDMI transmitter.
