two_travelers's avatar
Oct 14, 2016
dirty film on windows
Have a dirty film on side windows of motor home that I can't seem to get off, it's almost like a wax. Tried mineral spirits as well as vinegar. Vinegar seemed to help but it still there. Any suggestions on what I can use to clean the windows. What about Bar Keeps friend? It can be used on shower doors, tile fiberglass etc.
  • I recently used liquid Barkeepers Friend on a Mothers sponge ball on my drill and it took the hard water streaks off of my windows. The streaks looked to have been on there for a long time. They came right off and the glass looks like new.
    As I recall I wet the glass with a rag and then used the BF and wiped them with another wet rag and dried them. Not a streak left.
  • JoeH's avatar
    JoeH
    Explorer III
    Get a clay bar at any auto parts place or wally world. Rub the glass and it will take off the crud
  • Use Lime-away on a rag/sponge and rubber gloves. This will remove any calcium deposits and other dried deposits from moisture. Keep it away from painted surfaces and rinse thoroughly after you clean the window.
  • If it's not an internal film on a dual pane, I've had the best luck with ultra-fine polishing compound from an auto paint shop. Just tell them what you want it for and they will sell you the right thing.
  • Anonymous's avatar
    Anonymous
    Are you sure it is not the film on the inside of a dual pane window?
    JimR
  • 0000 steel wool is used on windows and headlight housings to clean them. It will rust quickly if left damp. Do not reuse if you get it wet.
