Well you got a difference in requirements. The best bang for the buck is an open face antenna on a tripod. The drawback is it has to be set up and aimed each time you move. The easiest would be an automatic portable like the DISH Tailgater, drawback it only receives western arc satellites so blockage by trees etc. is possible. The best portable for DISH is the Winegard Pathway X2. It will receive either DISH eastern or western arc satellites and has a larger antenna surface for better reception in bad weather. The drawback is it is somewhat bulky and takes up a bit of storage space when not being used.
