rgatijnet1
Feb 27, 2020Explorer III
Just be sure to not let the fluid reservoir to get dry or you will get air in to the ABS module, which is a little difficult to bleed.
The rest of the brake lines can be either pressure bled or vacuum bled for the same results. My WH takes about 3 quarts for a complete flush every two years.
38,773 PostsLatest Activity: Apr 24, 2026
