- SuperGewlExplorerI recently finished a cross country trip in my rig and yes the F53 chassis does very well up and down the grades while towing. I must admit that Ford did a good job on the Tow/Haul (Grade Brake) programming. If you use it in conjunction with cruise control you will be very happy. There will be a few times when you have to use the brakes to help the program be more aggressive when necessary.
Add a 5 Star Tune and it's even better. - RayChezExplorerHolstein, Nice Newmar Kin Aire, but the picture shows it with a hump on the roof. It is not like that, is it? I think maybe it is just a bad camera shot.
- holstein13Explorer
kgard1225 wrote:
Thanks for all the replies. I wasn't sure if the engine rpms would get too high going down a steep descent keeping in a low gear. All of the late model gassers I have been looking at had Ford chassis with the V-10. What is redline on these motors ?
I looked into this one time and read that the Ford V-10 doesn't have a redline because the computer won't let it over-rev. That has also been my experience. My old engine upshifted when the grade declined forcing me to hit the brakes to get to a slower speed where the transmission would stay in a lower gear.
I'll also add my vote of confidence in the V-10s engine braking abilities. It's not perfect, but certainly works well enough for the vast majority of the mountains I've crossed on the Eastern and Western parts of the country. I've only had to hit the service brakes a few times to slow down. - TerryallanExplorer II
zman-az wrote:
I don't know what year the tow/haul mode was introduced into rv's, but I would not buy one without it. It makes a huge difference descending grades. I got a dp now but had a 2011 f53 and that tow/haul mode is awesome and just as effective or better that a exhaust brake.
Even before Tow Haul. Gas engines had GREAT braking when down shifted. My 04 150 does not have tow haul. But all I have to do to slow down the vehicle. Is pull it back to 2nd, or 1st. It will make you fall forward against the seatbelts - phnguykExplorerFords newer torqueshift.
- DanTheRVManExplorerWeeding thru the bias and misinformation on this thread is difficult IMO
I would still like to see quantitative values based on weight/hp. Sorry but I have had too many physics and engineering courses to ignore these type of analysis.
But lacking that and other good information I would have to say BOTH go down hill safely IF you do not go faster than the system can handle. - willaldExplorer IIBottom line is this: Don't let concerns over braking on steep hills affect your decision one way or the other, when it comes to gas vs. diesel.
Its been debated many times, the differences between the two. Gasser engines naturally provide braking by virtue of suction created at the top end when closing the throttle valve. Diesels on their own have no engine braking, but adding an exhaust brake that plugs up the exhaust give them that braking. In the end, both do a good job of slowing things down when they need to, but do so in different ways.
Its not really accurate to suggest that diesels offer engine braking and gassers do not, when the reality is the exact opposite - Gassers provide braking naturally without having to add anything, diesels do not, and only get such by adding an exhaust brake that plugs up the exhaust.
Ultimately, though, since both accomplish the same basic thing when it comes to braking...There are much, much more important factors to consider when chosing between the two drivetrains. - Old-BiscuitExplorer III
rgatijnet1 wrote:
redguard just sent me this as a PM in reference to my post where I said that gasser RV's have no problems in the mountains with either the climb or the descent.
"you obviously have not driven a larger A gasser loaded in the rockies etc as this statement is pure bunk simply put UNTRUE "
I'll let those of you that have driven their gassers in the mountains respond. I have never had a problem with my Monaco gas coach in the Rockies, but I also never had a problem with the diesel coaches I've owned in the mountains.
Apparently he wanted to call me liar in private. Oh well! :B
As the above posts already seem to indicate, gas RV's do fine in the mountains.
redguard is a troll - zman-azExplorerI don't know what year the tow/haul mode was introduced into rv's, but I would not buy one without it. It makes a huge difference descending grades. I got a dp now but had a 2011 f53 and that tow/haul mode is awesome and just as effective or better that a exhaust brake.
- carringbExplorer
lostdog wrote:
There is no redline for these motors. The computer will not let you hurt that motor. I've seen 5000 plus RPM on our rig when going down a very steep grade but the V10 was holding speed just fine. I use a combination of Cruise Control and Tow/Haul.
Well, technically they do have a redline. You just would never reach it with the stock programming. I have raised my shift points to 5200 RPM and the fuel cut to 5400. So far so good at 394,000 miles except I can now hear some occasional timing chain slap (worn guides I'm sure). Would the guides have lasted longer without so much time spent north of 5,000 RPM? I don't know, but doing a timing chain job every 400,000 isn't exactly going to break the bank, and I sure like the extra power on tap.
38,766 PostsLatest Activity: Jan 10, 2026
