Grit_dog
Oct 06, 2023Trailblazer
Just because the vehicle is bigger doesn’t mean the difficulty of the service is anymore.
Seeing as an engine oil change is arguably tied for first place with maybe changing a tire as the most basic actual service, you’ll be fine.
Actully less risk since you don’t have to jack up the Moho to change the oil.
1. Take out drain plug, drain oil.
2. Replace drain plug and tighten snug tight.
3. Remove oil filter. (Filter wrench or big channel locks pretty much required)
4. Clean off filter surface put a skim of oil on new filter gasket and screw on new filter hand tight (as tight as you can get it by hand. Do NOT use tools to tighten).
5. Dump in required amount of oil.
6. Crack open cold beer and toast yourself for doing a $200 service for like $50!
