deereone
Aug 07, 2013Explorer
3 RV's with valve extenders and none leaked. Tighten a little more than finger tight. Make sure they are installed so they don't flop around when on the road. Using non-flexible stems to match your needs helps. Using flow through caps makes it easy checking and adding air, even on the inside duals.
38,777 PostsLatest Activity: May 24, 2026
