two_travelers's avatar
Jan 09, 2020
Dually valve extenders
Will be buying new tire for the coach shortly to be ready for the up coming season. Currently, the inner rear dually has a braided extension. I've never had good luck with these and plan to replace them with solid ones when I get new tires. My tire shop is proposing solid extenders that replace the existing valve stem for $160. I see that you can also buy ones that screw on to the existing valve for a lot less money. Is one better than the other? It would seem that the expesive ones eliminate a schrader valve and a point of potential failure.
