wa8yxm wrote:
willald wrote:
Nothing wrong with the braided extensions, as long as you make sure and get ones that are AIRLESS. Meaning, no air pressure in the extension except when you attach a gauge or air hose.
If you scroll back you will see where I posted "one worked one did not".. Guess what. they were airless types.
I'm curious as to specifically what you meant when you said that one of the braided extensions did not work?
By did not work, did you mean that it leaked out air? If so, I'm really curious how, as if they are truly airless, there is no air in them to leak out? They could work themselves completely loose, or even fall completely off, and still no air can leak as there isn't any air pressure in them except when you put a gauge or hose on it?
