Kidoo's avatar
Kidoo
Do you have to run AC or Heater on the road
I am looking at buying a Class A. I was wondering if you have to run the RV roof Air conditionner when driving in warm weather or using the furnace when driving below freezing temp and is it enough to keep the RV comfie?
I guess different brand would make a difference, thermo windows, insulation, lenght, big or small window, ect.
What would be the lowest or highest temp to drive the RV and stay confortable.
I am also looking at a Gulfstream Independence 8295 2006 with the Workhorse, 3 slides with the one sun room slide out with 3 big windows table and chair, 5 windows when open plus 3 sky window. Would it be hard to keep warm on the road near freezing?
http://www.gulfstreamcoach.com/products/gas-motorhomes/independence/8295.htm
Thanks
  • It would partially depend on whether there will be passengers in the back, or just driver and co-pilot. If others are in the coach, there may be a need for extra heat/cooling in the main part of the coach.
  • When it's really hot or cold short answer is yes. Use the generator to run A/C when real hot. Furnace will run on 12V for when it's cold.
