Ocean_Mist
Jun 08, 2017Explorer
Nutinelse2do wrote:
Leave the propane on for the fridge during travel. It's the same as your 99 Dolphin.
If it's a Norcold fridge, call them with the model #, and serial #. They will tell you if the mod has been done, or if it's even needed. If not, have Premier/ Premium, where the coach is, do the mod for you. Takes them all of 10 minutes to do it.
If you want to run it off the inverter, turn the inverter on, and switch the fridge over. Easy peasy.
This is the kind of helpful informatin i really needed. I was getinga bit overwhelmed, and just needed a friend to kinda walk me thru the process...
I mean I'm the same way. I like to make it as easy as possible and as clear, when I'm helping other friends in that particular hobby..
The seller had the Maytag Residential Frigerator in there, so I assume it's all plumbed for the Residential Frige...
On the Data Sheet it says I have the MAGNUM MS2812 Inverter. Is that one sufficient power, desired one?
38,763 PostsLatest Activity: Dec 05, 2025
