ezgoinExplorerJun 09, 2020Do you leave MH plugged in for power at home?Just asking. Is it OK to leave MH plugged in when stored at home? I use a 20 amp outlet and an extension cord, but wondered if it is Ok to leave it for extended periods of time. Thanks, Ezgoin’Show More
wildtoadExplorer IIJun 09, 2020I keep mine plugged in. But suggest you open your purse and install an outlet for the amps your unit is designed for 30/50.
Related ContentDo you leave plugged into shore power...?7 pin plug amperage rating?Shore power plug conversion?Adding power outlets in slide with no wiringNewbie power question
