Hikerdogs
Aug 18, 2013Explorer
RinconVTR wrote:bobkatmsu wrote:2oldman wrote:2007 Safari Simba with a Onan 5500 generator.
Is this a really old generator?
gas treatment post
Well before 2007, practically all small gas engines (carbs, jets, fuel lines, seals and gaskets) were built to run on E10 gas.
We've been running E10 since the mid-90's, exclusively. The issues in the mid-90's when E10 came out was engines running too lean (burning holes in pistons and overheating valves), not much more. The rest was hearsay and tails.
So while I'm against the grain here, I'm 100%, yes 100% sure E10 gas is not to blame. As with any rubber hose, from any time in history, they fail. It could be an age issue, temp, environment, or simply old gas that ate that fuel line. It happens!
E10 is here to stay, and if you don't like E10, well brace yourself for E15 and fewer stations who carry straight gas. Its only a matter of time.
Don't kid yourself about the damage ethanol can do to small engines. I have over 20 pieces of equipment including, lawnmowers, weed eaters, leaf blowers, chainsaws, rototillers and snowblowers. Most of them are less than 5 years old. I was replacing gas line every six months on multiple pieces of equipment because it either swelled and started leaking, or got brittle and broke into pieces. None of the lines on any piece of equipment lasted more than a year. It got so bad I was buying gas line by the 50 foot spool.
About 2 years ago I switched from regular gas with 10% ethanol to premium non-ethanol gasoline. I'm sure there's no benefit to using the premium grade, but it's the only thing I can buy in our area without ethanol. Since I switched I haven't had to replace a single fuel line.
38,769 PostsLatest Activity: Apr 04, 2026
