wa8yxm
Aug 16, 2018Explorer III
Big Katuna wrote:
Sounds like an awning loop. Used to open your awning. Look for s loop of fabric near the middle of the awning.
Also handy as a fire poker.
Yes that is the Awning Rod NOW if you have power awnings you wont have that loop but with manuals it is used to Flip the latch then you hook the loop of fabric and pull it down,
(On autonmatic electric awnings you will have the "Strap" in your owner's manual bag or should have. for when the Motor fails. Read the instruction manual)
FIre poker.. I use mine to snag "pads" under my jacks or planks under my tires and a host of other "I need longer arms to snag something) uses.
One of the handier tools that came with the RV.
OH. in another thread folks were discussing how tight sewer fittings and outlet caps are.. I should hope they are tight. but on my RV it's hard to reach in and get a good grip.. So a slip joint type oil filter Plier type tool Like you might use to change oil filters.
Been lugging that thing around 13 years and just recently figured out IT IS PERFECT for the job.
38,778 PostsLatest Activity: Jun 10, 2026
