John___Angela
Feb 24, 2013Explorer
junkyardcat wrote:John & Angela wrote:junkyardcat wrote:John & Angela wrote:pianotuna wrote:
Hi,
The Trik-L-Start will work. The tech does not understand you are not attempting to "boost" the chassis battery with the Trik-L-Start.
Some RV's do have the ability to charge the chassis batteries while plugged in.
Totally agree with the above. The tech may have thought you were attempting to charge the batteries when in fact all you are trying to do is maintain an existing charge. The trikl start among others is a very good solution for your situation.
Although some coaches have systems that charge the chassis batteries after the coach batteries are charged I don't believe yours is one of them. There is a forum member named Bounder Lew who has a lot of knowledge on the bounder line that may be able to give a better answer.
I do beleive the OP question has already been thourghly answered in previous posts.Surely any tech worth his salt would have quized him as to what he needed the battery minder system for?
yes but as you pointed out maybe it wasn't a tech worth his salt. :)
Yes I agree.You say you have been in sales so iam pretty you see alot of that in your field of work
Well I can't say I have seen a lot of bad techs but I have seen more than a few mis-communications between customer and service manager or tech I am sure It happens in all trades. :)
38,773 PostsLatest Activity: Apr 25, 2026
