luberhill
Sep 17, 2018Explorer
donn0128 wrote:
Refer used 12VDC for control voltage. It is needed for all operations
Using 12VDC for heat would kill your battery in about 15 minutes. Same for the water heater. Propane is cheap and plentiful. So using it as a heat source only makes common sense.
Ha I didn't think the furnace would use 12v dc for heat, I thought it would use AC when plugged in or on the gen
38,777 PostsLatest Activity: May 24, 2026
