Chum_lee
Sep 06, 2018Explorer
Spraying a little WD-40 at the squeak/rattle will help you locate the source. After you clean the surfaces, if you can put 3M double sided foam tape between to two surfaces that cause the squeak/noise, then refasten them, that will help reduce the noise, for a while. On surfaces that open/close regularly, use single sided foam tape or those round felt stick pads for cabinet drawers/doors. (you'll never get all the squeaks)
Chum lee
Chum lee
