randco
Jun 06, 2013Explorer
peaches&cream wrote:Tom_Anderson wrote:two-niner wrote:
All of this "sitting in the cab pumping the brake pedal X number of times" is good. How do you know they really adjusted??
You measure the stroke, just like always. All of this pumping stuff isn't really necessary if you measure the pushrod stroke and it's within spec.
No one has answered my question, does the pedal go lower (as in hydralic brakes) as the adjustment gets out of tolerance? Or does the pedal go to the floor upon a stop when it is out of tolerance? Since we have professionals responding to the post, I would think they would know the answer? I normaly press my brake pedal as far as it will go, every day as I drive the MH. Usually make at least 10 stops or more each day. Do I need to do a "panic stop"? Please explain what a CDL teaches you over a "peon" like me?
Give me some info?
I suppose for peon's like us, a panic stop will be required after we do a walk around and crawl under the rig and inspect the brake assembly, then make certain that the all of the tire pressures are perfect and that the engine is up to operating temperature. Oh, one last thing, make sure that any loose items are properly secured prior to the panic stop.
Next question... At what speed must one be traveling to perform the proper panic stop?
38,782 PostsLatest Activity: Sep 10, 2026
