msmith1199
Jun 06, 2013Explorer II
Tom_Anderson wrote:msmith1199 wrote:
"You would fail the CDL test. You forgot the walk around which requires actual checking of the slack adjusters and brake pads, drums or rotors"
You're supposed to do a walk around and check brake pads? I could not do that with a walk around, at least I don't think. I'd have to do a crawl under and I'm pretty sure even with crawling under on the drum brakes you can't even see the pads without taking the drum off.
Yes, if you're driving a commercial vehicle, you are supposed to do a complete inspection every day. Obviously, if you can't see the brake shoes without removing the drums, you're not expected to check them. Again, this is only for commercial vehicles, or the CDL driving test.
But I think people are arguing you should do the exact same for your RV as is required by the CDL. Once nice thing about the big rigs is many of these things are readily available to see. They aren't so easy to see on a motorhome.
38,782 PostsLatest Activity: Sep 10, 2026
