- SantaflowExplorer
gbopp wrote:
Do you have low flow from the hot or cold side of your faucet, or both sides?
Did you unscrew the end of the faucet where the water comes out and clean the screen?
Did you look under the sink while the water is running to look for leaks?
Hello,
I checked under the sink and the pipes from there to underfloor are ok. Also the pipes from the water pump to underfloor are also ok.
The car is a big sur 225. There is any way to know the planes of the chasis?? So I can know how to access to the plumbing.
Thanks - gboppExplorerDo you have low flow from the hot or cold side of your faucet, or both sides?
Did you look under the sink while the water is running to look for leaks? - SantaflowExplorer
gbopp wrote:
Santaflow wrote:
I'm handling a wattering problem from the water pump pipes to the sink. .
Are you talking about a leak or are you not getting water to the sink?
Hello,
It’s both, I get water but with not much pressure and the floor gets wet and also the car leaks underfloor.
Thanks. - gboppExplorer
38,778 PostsLatest Activity: Jun 10, 2026
