mrkemanExplorerApr 17, 2017Doghouse insulationHas anyone insulated the doghouse in their class A gas? Mine is very hot and loud. Thanks in advance for the help.
wildmanbakerExplorerApr 17, 2017Yes it helps to quite and it also helps with the "heat soak" after you stop and set-up, coming from the engine area.
Related ContentSound insulation of doghouseReplace insulation inside heater column.Remodel insulationDoghouse removalInsulation
