Cookboy1ExplorerOct 09, 2014Dometic 1292Hi folks, Newbie here. I have an 04 Pacearrow, Refer had always worked great. I was getting ready for a trip and found fridge not working on gas or electric. I checked the fuses on the power board ou...Show More
Old-BiscuitExplorer IIIOct 09, 2014Dometic doesn't use a control module (LED light) like the Norcold Recall....so forget about the LED light issueThe thermodisc on flue is used to shut down all dc power to fridge when it senses high temp eventForce cool fridge......unplug thermistor and run fridge on AC overnight.Check food section fin temps....fins should be at least 30*F or lower IF food section fins do not cool down then cooling unit has blockage.If food section does cool down....then thermistor is faulty
Related ContentDometic NPR 1292 Ice MakerDometic Refrigerator NDR 1292MH Dometic NDR 1292 Refrigerator Stopped Working?Dometic NDR 1292 No CoolingDometic Servel RGE400 fridge too cold
