Hi folks, Newbie here. I have an 04 Pacearrow, Refer had always worked great. I was getting ready for a trip and found fridge not working on gas or electric. I checked the fuses on the power board ou...
1. The Thermal disc should NOT melt. If it did, that means you had a ventilation blockage and that caused the flue to extremely overheat and the Disc did its job. I have NEVER seen the Thermal Disc melt. Trip, yes, but never get heat damaged. 2. You need to verify ventilation up thru the roof and if IN a slide, verify that the AUX rear cooling fans are operating. Doug
