Hi folks, Newbie here. I have an 04 Pacearrow, Refer had always worked great. I was getting ready for a trip and found fridge not working on gas or electric. I checked the fuses on the power board ou...
Disconnecting the thermistor will allow the fridge to run continuously. You might see some ice start to form on the fins. This will be normal. If so, then your thermistor is bad. My guess is with Doug on this one. If your thermal disc melted, you've got a blockage up top. Not sure if Dometic used rear cooling fans like Norcold but makes sense that they would. I'm guessing birds nest though. Check it out and let us know...Dennis
