newman_fulltime
Oct 21, 2018Explorer II
dougrainer wrote:newman fulltimer wrote:
your freeze sensor plug on your controller box is loose unplug it plug it back in should fix it
Wrong sensor. The code is for the AMBIENT temp sensor. What is strange is, they rarely fail and the OP states he replaced it about a year ago. He needs to check his Ambient sensor and how it plugs into the upper control board. Doug
I know the code says ambiant sensor but for some reason I have found to many times the freeze sensor fixes the issue
And it is the white wire that goes into the coil and plugs into the box in the ceiling
38,773 PostsLatest Activity: Apr 25, 2026
