thestarfinder
9 years agoExplorer
Dometic Comfort Control 2 Thermostat issue
Dometic Comfort Control 2 model#3314080.xxx(without dehumidify)
My zone 1(front AC/HP) HP mode seems to be stuck on HP/FURN it trys to start then it flashes HP then to FURN and will not run the heat pump on the roof(it has never done this in the past) It started when it went into the defrost mode and when it tryed to start the heat pump it is now showing the HP/Furn flash back and forth.
It is not connected to a Furnace....somehow it thinks it wants to switch to a furnace that it is looking for but cant fine because it is not hooked up to one.....I'm hoping for a reset button on the roof unit...I looked for one under the shroud and in the compartment where the mother board is.and couldn't find a obvious reset...
I have it for 4 years and never had a problem.....
The AC(Cool mode) works fine....The Auto mode works fine...
Zone 2 the (back AC/HP) works fine in all modes....
Any thoughts will be appreciated...Thanks in Advance,Tom
