dougrainer
Mar 25, 2017Nomad
1. It is connected to a furnace. You may have a Aqua hot but that is a furnace for the system. Your profile shows a 2001 Windsor. That means you have had to have removed the original CCC control and went to the CCC 2 system. Once you do the reset Chris listed post if that fixed it. What is the outside temp you are in? Doug
If the reset does not work I would suspect the ambient temp sensor
