jimzhr's avatar
jimzhr
Dometic Elite Fridge RM 7732 GONE
My rig is a 2000 National Tradewinds 7371.
My fridge is the original in this coach. It is a Dometic Elite 2-door fridge w/ice maker. The cooling unit has gone out so I either need to repair it, at an estimated cost of $1600-1800, or replace the fridge. The repair cost is high because a number of people have suggested buying a new cooling unit from Dometic rather than any unit from any other source due to failure rates of bad parts/suppliers in the market.
I really don't want to repair a nearly 15 year old fridge. I'm considering trying to put in a residential fridge but am leaning toward a new Dometic Elite 2+2 which I believe is the recommended replacement for my unit.
I have a new Magnum 2000W inverter and 4 house batts which should run a residential unit on the road and while boondocking, Others with these units tell me that should be no problem.
The prime reason I am leaning away from the residential unit is the difficulty finding a unit which will fit well into the hole and require a minimum of woodwork to finish the job. I just cannot seem to find such a fridge. Though the new Dometic will be much more expensive, I'm thinking that it will be a better fit and much less hassle having the unit ordered by, and installed by, an RV dealer experienced with these units. At the moment I am in south Texas and am considering having Camping World, New Braunfels, order and install a replacement.
I have read a number of posts on fridge replacements but none have been specific to my coach or fridge. What I am looking for here is someone who has replaced the old Dometic Elite in a Tradewinds or other similar rig and specifically what they replaced it with. Residential or RV fridge.
Thanks in advance for any help here!
Jim
  • As stated there are a lot of threads on this. I ditched the Not-So-Cold and went with the Samsung 197, now I can sleep at night plus I switched to the Magnum 2812 inverter.
    Don't know the size of your frig but here is just one install.
    http://rvseniormoments.com/projects/residential-refrigerator-upgrade/
    You have the new Magnum 2000W inverter so you are good there for any frig.
    I would never have Camping World do the install, do some checking for installs.
    JR
  • Hi,
    There are lots of threads and many folks have gone residential for fridges.
    I would look at the 12 volt Nova Cool line up and see if something will fit.
