AsheGuy
May 11, 2016Explorer
lucytravel12 wrote:This is exactly the symptom of a clogged burner but since you say it now does not work on DC or 110 it must be something else. How long did you let it run before you decided it did not work on the electrical options? Don't jump to a quick conclusion that it is not working on electric power. Ours has always worked best on propane.
It does have a flame, it's not strong enough to heat well.
You say it was cleaned but did not specifically say the burner had been cleaned. The burner can be replaced (I did it on ours), it's not that complicated but does require disconnecting the propane supply. If it really does not work on any of the modes then your guy may be right, it would be better to replace it.
It sounds like our LTV in which we had to have the generator replaced last fall. It was not cheap but the only option, it would have cost more to fix it.
