kuzined's avatar
kuzined
Dometic fridge door
Have a 05 Fleetwood with a 2-door side by side Dometic fridge. On the big door, when it is closed, it will not seal tight. I was able to give it a little push and it would seal tight but in the last couple of days, it will not stay tightly closed. I cant see the hinge being out of adj. Is it possible the rubber seal around the door needs to be replaced? The temp still stays at 41 degrees.
  • Koop wrote:
    My Dometic NDR1492 side by side two door refrigerator lists PN 3108708.474 as a replacement seal kit from Dometic. The problem is, the seal kit costs $325.
    It is also a 3 day job. You must remove the doors and let them get to room temp, then after cleaning and installing the new gasket, you MUST let it dry/adhere for a minimum of 48 hours per instructions. Doug
  • My Dometic NDR1492 side by side two door refrigerator lists PN 3108708.474 as a replacement seal kit from Dometic. The problem is, the seal kit costs $325.
  • The door seals are not available from Dometic... However, I searched thru google and found aftermarket seals for my Dometic NDR1292 fridge.... the originals were installed as the door was assembled.. the aftermarket ones install on the inside face of the door with double face tape.... requires removal of doors, cutting away old gasket, cleaning, carefully installing new, letting sit flat for 24 hours... did mine 2 or 3 years ago... great results...
  • Agree with Dougrainer, I have the same fridge and numerous times when the door alarm beeps, it is something just a little too long front to back or shelving not pushed in.
  • I would check and make sure the bushings on the door hinges are not worn. If they are, replace them. As Old-Biscuit posted, the seals themselves are not replaceable, no part number is even listed.
  • Are you POSITIVE that there is nothing that is hitting the door on the inside. I have had numerous times that customers come in and when I look inside, they have a shelf or some type item that is hitting one of the door trays and will not allow that door to freely pull tight and allow the magnet to do its job. Doug
  • No 'gasket' kits available.......non replacement item.
    New doors only
    Clean the frame surface
    Clean the gasket face
    Make sure doors are sticking frame evenly..have not slipped/sagged down. (worn hinge bushings)
    One other thing you can try: (last ditch attempt)
    Place a ball of cotton in each corner under the gasket
    Then heat gasket material until warm....using hair dryer. Takes a while due to size of gasket....get it warm
    Then close door and let gasket reset......20 mins. or so
    Then remove balls of cotton form corners
  • probably the magnet in the rubber seal is getting weak, replacing the seal would be the first thing I would do since the hinges look OK.
