dougrainer
May 21, 2015Nomad
Your type of lack of cooling will not be the Thermister. At this point if you have no yellow leakage at the burner area, you hot wire BOTH 120 heat elements for 24 hours. That will operate the unit at full cooling. IF after 24 hours the water in the refer is not below 36 degrees the cooling unit is bad. The side by side Dometics require the rear coil 12 volt fans to operate. But, fans not operating will not cause your high temps in the refer. Really need you to post model number of refer and do you get any error codes. Doug
