YC_1
May 21, 2015Nomad
Is this in a slide out? I am wondering if you have the side vented setup. If so, listen for the fan or fans that should be running when it getting hot in that area. I had to look downward inside the top/side opening that is and found my fans were not running.
The other issue could be a cracked drip tube. What is your drip tube setup?
