dougrainer
May 23, 2015Nomad
bluwtr49 wrote:YC 1 wrote:bluwtr49 wrote:
UPDATE:::
After running for several days with no change in temp, yesterday morning the freezer was at 0 and the fridge at 30. No idea what changed. I wonder if there was a "bubble" in the coolant that suddenly cleared.
Whatever it was all is well now and that's what counts.
Could easily be an intermittent fan.
I will ask again. Does your refer have a top vent or two side vents? One normal one at the base and one at the upper edge of the refer.
The Dometic does't seem to have fans and it's a top vented model...not in a slide. Right now it's sitting in the barn with a temp of 91 degrees. Ambient temp has not change significantly over the past few days.
Cooling units do not get a "bubble". I asked for the model number. Why is it so hard for people on these forums to NOT answer a simple request and they ask for help?????????? Most Dometic side by sides DO HAVE cooling fans. THAT is why the model number request was made. Doug
