LetsRV wrote:
Okay, get the electric issue and thanks for the help.
Now another question: Had RV parked by the house for 14 years. Was not quite level but fridge was never a problem. Would run it for a day or two prior to trip.
Finally needed new fridge in April (gee, almost 15 years old on previous fridge). Due to unexpected health issue just now getting to use the RV this year. Anyway RV is now in storage lot but will be brining it to the house to clean-up and load-up for trip. If new fridge runs for three or four hours not perfectly level (about a bubble or bubble and half off) will it be okay???
Will it be OK. Probably. But, Refer out of level is a cumulative process over the years. ALL those times you ran off level (out of spec off level) for a few hours or even days, you do NOT notice any problem and you think, I guess level is not that important. But, as I stated, ALL those times short and long the blockage starts out very small and slowly accumulates until one day the refer just does not cool as well as it once did. You just think, well it just went bad, NO, they do NOT just go bad. They will run for years and years with no problems as long as you do not run off level for even a few hours. Doug
