johnsonbert
Jul 02, 2015Explorer
Dometic Heat Pump will not stay in cool mode
My Dometic heat pump will not stay in cool mode. After running for about 3-4 minutes in cool, it reverts to heat mode. I checked the solenoid for tightness and it seemed fine. I did not yet check the resistance on the coil itself as I did not want to disassemble the wiring yet. It appears that one wire form the solenoid goes to the circuit board and it appears by the wiring diagram that the other goes to a post on a start capacitor. Is there a way to narrow down the possibilities of either the solenoid, capacitor, or circuit board. All other functions seem normal, except for the solenoid releasing the reversing valve. It appears the reversing valve is working as it is supposed to. Thanks in advance for any suggestions you may have. We are on the road so may be a tough fix as we will not be in any location long enough to order a part. Thanks again for the help. Bert
