- newman_fulltimeExplorer IIcall a regular heating and ac guy theycan replace the coil most have them on their trucks
- kimbo1Explorermodel number and serial number is under cover where caps are.
- Arizona_KidExplorerIf it's a Roadtrek call the factory.
It would help if you gave a little more info, like year, RV manufacture, brand of Heat Pump,etc. - Mandalay_ParrExplorerMine would only heat and would not go into the cool mode.
Dometic could not send the proper coil for the solenoid valve so they ended up replacing the whole unit under warranty. I had to pay for the labor.
38,707 PostsLatest Activity: Jan 05, 2014
