dougrainer wrote:
I guess I don't understand what he means by advertising "truthfully". You advertise a RV refer. You either list the icemaker or not. WHY would you have to know or care about an Icemaker Install cost and availability?????? Except for Norcold Freezers That the Icemaker is mounted on the back wall(using the freezer plate screws already there), both Norcold and Dometics DO NOT have the mount holes for the Icemaker in the freezer compartment. You will have to drill and install the screws in the plastic wall. Doug
Just as an FYI, there are four hex head screws already installed in the metal plate on the freezer sidewall that appear to be for the harvester and two plugged holes in the back wall that appear to be for the water inlet and the other is for????? Perhaps the wire harness??
As to why I care, I guess I'm still in the "solve issues before they become problems mode" from my days of working with clients.
