dougrainer
Jul 29, 2014Nomad
Ro646a wrote:
Well I opened up the automatic transfer switch yesterday to check connections, etc. All the connections were tight and there was no obvious evidence of a problem, although the contacts were pitted on the generator side of the relay. I ordered a new transfer switch, but I doubt that it was giving me any trouble, since it is on the power cord side that I am having issues when running my rear A/C unit.
Doug,
You seem to be pretty knowledgeable about the Penguin II. Can you tell me how I would be able to identify whether or not my unit has the 12 to 5 button conversion kit? I have the 5 button thermostat controlling both my original Penguin unit up front and my "new" Penguin II unit in the rear.
One thing that may be a clue here, is that although I am able to select either unit 1 or unit 2 using the zone button, both number 1 and 2 are always visible on the display. I don't recall seeing both unit numbers displayed at the same time on the same style 5 button thermostat in my old Dutch Star, with the 2 Penguin units.
Any thoughts?
And thanks for all the assistance from all of you so far.
Roland
You will see both zones. The one that is "active" will flash. I made a mistake on my original post. IF you have a regular AC, no Heat Pump, you may not need the 12 to 5 conversion. The only ones I have done were Penguin 2 HP's. But, the 12 button regular board cannot communicate correctly with the 5 button system. ON the 12 button Board, you will see 2 soldered spade terminals to one side with the White neutral wire on one of them. There may be a white wire on both. The 5 button does NOT have those side by side Neutral spades on the board. According to Dometic, if you try to use a 12 button with a 5 button wall CCC you will get a "EE" error code. The 12 button ALL the low voltage quick connects are on the END of the board. The 5 button board these quick connects face straight up on the board. SO, if no EE code they installed the 12 to 5 board, but may have connected it incorrectly. Doug
