Big_JimmyExplorerJun 08, 2021Dometic Refrigerator2011 Tiffin open road with a Dometic Refrigerator with long, loud and offen running -cooling fans. Coach is new for us and not sure if this is normal! Thanks
1 ReplyReplies sorted by NewestOld-BiscuitExplorer IIIJun 08, 2021OEM Fans are cheap junk....But essential for airflow/heat removalT-stat controlled.....it's attached to Condenser FIN (top of fridge)turns fan(s) on at 130*F FIN Tempturns fan(s) off at 115*F FIN tempOutside air temps above 85*F...fan(s) will run If in slide out...t-stat/fan can be reached via upper vent/access panelComputer fans are better and use less DC amps
Related Content12 volt only refrigeratorDometic RefrigeratorDometic refrigeratorDometic Refrigerator E3 codeDometic refrigerator
